August 27, 2019 at 11:46 am
thilliard
SubscriberOk so what I am trying to get is all the P values (jigz.txt file) change for every job and I pull the values from an excel worksheet now I need to pass those into my script. How is this done? trying not to have to hard code them each time Thanks
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
August 27, 2019 at 2:14 pm
Naresh Patre
Ansys EmployeeHello frogdude01
You can read the text file and store all the data from the text file for using it in your script. There is a built-in example showing how to read a csv file in the snippets section which you can refer. See below snapshot. This snippet can be accessed in Insert Snippet - Reading from Files - Reading From a CSV File. You can use similar logic to read txt file and use the data from the txt file in your script.
August 28, 2019 at 8:02 am
thilliard
SubscriberI tried that I don't know how to pull the information so that in my script P1 will equal 7.125 that is in the text file. I'm a total newbie at this stuff
August 28, 2019 at 10:18 am
Naresh Patre
You will have to make use of basic python functionalities like split, dictionary and so on. Please refer below sample code:
f = open("E:\support\forum\JIGZ.txt", "r")
my_dict = {}
for x in f:
temp = x.split("=,") # split each line by =,
my_dict[temp[0]] = temp[1]# Sketch Line UPPER S DIA 'P5')
start = Point2D.Create(MM(-1*float(my_dict['p1'])*25.4), MM(float(my_dict['p5'])*25.4))
end = Point2D.Create(MM((-1*float(my_dict['p2'])*25.4)-R1), MM(float(my_dict['p5'])*25.4))
result = SketchLine.Create(start, end)
# EndBlock -
August 28, 2019 at 1:41 pm
thilliard
SubscriberThank you will be doing some Python tutorials to be better scripted :)
- Can’t see license on online account
- loss of user settings
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
3744
2573
1809
1236
594
