April 14, 2023 at 9:31 am
Oussama Hajjaj
SubscriberI wrote a script to rename the mechanical analyses according to their name in WB, but the problem is that if the analyses share the same model, they will have the same name as the last one in WB. the code is written in the script editor on Workbench.
cmd="""
for analysis in Model.Analyses:
analysis.Name='noname'
oldname='noname'
systems=GetAllSystems()
for sys in systems:
try:
model= sys.GetContainer(ComponentName="Model")
newname=sys.DisplayText
cmd=cmd.replace(oldname,newname)
model.SendCommand(Language="Python",Command=cmd)
oldname=newname
except:
pass -
April 17, 2023 at 7:00 am
Aniket
Ansys EmployeeSo do you want to rename systems in Mechanical as per their name in Workbench system? From your script it looks like you are assigning 'noname' string to every system in Mechanical.
-Aniket
April 17, 2023 at 7:57 am
Oussama Hajjaj
SubscriberHello , yes it's for my internship and my supervisor asked me to make a script to rename systems in Mechanical as per their name in Workbench system.
I want ton change it and have some help , noname is the oldname , when using the commands after, i can change it to a newname. i should make the first for loop over a list but in my case it's just over one name of the list and i don't know how to solve it .
3299
2469
