3D Design
3D Design
Topics relate to Discovery SpaceClaim, Discovery Live and Discovery AIM
Seat belt buckle
    • Mirvari Alimova
      Hi! I'm a ansys workbench newbie and I'm trying to simulate seat belt buckle in ansys. I don't know how to define a specific point as Fixed Support and how to find the force which I need to apply for that. If you could help me it would be great.
    • peteroznewman
      Hello Mirvari,
      Please insert an image of the geometry in your reply. Put a label and arrow pointing to the specific point you want to hold fixed and another label and arrow pointing to the feature where you want to apply a force.
    • Mirvari Alimova
      This is my seat belt buckle geometry, I need to apply 3 loads, so instead of force and displacement as my input parameters, I used 2 opposite forces. As my output parameters I need to apply the maximum equivalent stress and there safety factor should reach 1.5 of the minimizing mass. I also need to add mass, but I don't know how to add it. Finally, response surface optimization should be used.
    • Mirvari Alimova
      when i use response surface optimization it doesn't show input output parameters, instead of that I used structural optimization i should choose the percentage of retain, when i choose 50% it changes structure completely.
    • peteroznewman
      Hello Mirvari,
      In Workbench, delete the Topology Optimization system. Open the Geometry using SpaceClaim. On the Prepare tab, click the Midsuface button and click the two faces on this thin part. A surface will replace your solid model in Mechanical.
      In Mechanical, delete the Fixed Support and delete the Force on the lower edge. Reattach the Force on the upper edge.
      Insert a Remote Displacement on the lower edge. In the Details window, check the Behavior is Deformable and set all six rows to be 0.0 instead of Free.
      Drag the Remote Displacment and drop it on the Solution branch to insert a Force Reaction output. This will show you that the reaction force is equal and opposite to the applied force. Right click on the Solution branch to Insert a Stress Tool for Max Equiv Stress to get the Safety Factor plot. Click the box next to Minimum on the Safety Factor to turn that into an output parameter.
      One input parameter that is easy to adjust the mass is the thickness of the part. Click on the Midsurface under the Geometry in the Outline. Click on the box next to the word Thickness in the Detail window and a blue P will appear. Also click the box next to the Mass.
      In Workbench, there will be a Parameter Set. Now you can type in a set of thickness values on several rows of the Table of Design Points and click the Update All Design Points to have Ansys automatically calculate the Safety Factor for each thickness and report the Mass.
      Since you have only one input parameter, your response surface is a response curve, but you can plot the curve and find the value of the thickness when the curve crosses a value of 1.5 on the Safety Factor axis.
      Once you have mastered this, you can add shape parameters to the geometry and have multiple input parameters. Then you can introduce the Response Surface tool under the Design Exploration category of Workbench and minimize the mass by varying many input parameters including thickness.
    • Mirvari Alimova
      Thank you for your answer, but I have a question regarding to Midsurface button , when I have done that, it shows really thin belt on the mechanical. Could you explain why we need to do that?
      What else I need to do for  response surface optimization here?
    • peteroznewman
      Once you convert a thin solid to a midsurface, it shows as a zero thickness surface, but the elements that mesh that surface are assigned a thickness value.  There is a button on the Display tab in Mechanical to Show Thick Beams and Shells, and when you click that, you can see the original thickness if the part has been meshed.
      To do Response Surface Optimization, you need to add some parameters. The thickness assigned to the midsurface can be one. If you go back to SpaceClaim, you can add a parameter for the length of the part, the width of the piece the belt wraps around.
Viewing 6 reply threads
