October 19, 2018 at 3:16 pm
sameerfares
SubscriberHi All,
This is a joist seat that will be welded to support with 2" long fillet weld at the toes of bottom seat angles as shown. An uplift force(blue arrow) will lift seat up. So the only connection between the seat assembly and support is the 2" long fillet weld on the side(angle toe). The top angles and bottom angles are welded only on the inside with 3" fillet on each side. Under uplift load, the bottom angle horizontal legs will flex or bend and/ or the top and bottom angles may open up at the toe of the vertical leg of seat angle.
1. How do i model the support/seat connection?
2. Is welded treated as solid, but i need to assign different material properties for the weld?
3. How does Ansys know that the weld is connected to two materials together?
4. How do I draw a solid rod between the top angles? the rod will be welded to top angles.
Sam
October 21, 2018 at 3:08 am
SubscriberHi Sam,
Here is a video on making the four weld fillets on the edges. I will look at the rod next.
Peter -
October 21, 2018 at 8:16 pm
SubscriberHere is the rod video.
Peter -
October 22, 2018 at 1:58 pm
sameerfares
SubscriberExcellent. Thank you so much Peter!
Sam
October 23, 2020 at 2:59 pm
kaitova
SubscriberHi Sam, Peter, do you have example of the analysis after this geometry was completed?nThank you!n -
October 23, 2020 at 4:53 pm
October 25, 2020 at 3:01 am
SubscribernSince the angles are coming apart, I would say it is not right.nYou have used only one element through the thickness. You should mesh these solids with two elements through the wall thickness of the angles.n -
October 25, 2020 at 4:00 pm
kaitova
SubscriberThank you, Petern -
October 25, 2020 at 5:00 pm
kaitova
Subscribern -
October 27, 2020 at 8:46 am
kaitova
SubscriberHi Peter, @peteroznewman, thank you again for your advices.nI have finished the model, please see results, I have used steel material from the library. Load is 100N, BCs are shown below, autoscaling was used before, sorry. nThank younn
n
October 27, 2020 at 6:22 pm
SubscribernLooks good to me.n -
October 27, 2020 at 11:36 pm
kaitova
SubscriberThank you, n
2066
1279
1096
457
