second previous time step error
    • Silversea
      I wrote a simple UDF to get the previous time step values in a transient model in Ansys Fluent V2022. It worked fine when I used current time macros, e.g., C_R(c,t) or previous time step macros, e.g., C_R_M1(c,t). However, when I tried to get the second previous time step macros, no matter which one, e.g., C_R_M2(c,t), C_U_M2(c,t), or C_T_M2(c,t), I always get Segmentation fault error.
      Does fluent store the second previous time step values by default?
      Should I do something in fluent before accessing the second previous time step (_M2) macros?
    • Atharva Nagarkar
      A segementation error is usually related to incorrect allocation of memory or errors in writing the UDF.
      Can you please share your UDF?
      Thanks!
    • Silversea
      Thanks for the reply.
      This is the code I tested:
      Calculate the average velocity at outlet and print it.
      #include "udf.h"
      DEFINE_EXECUTE_AT_END(pre_time)
      Domain *d;
      Thread *t, *t_f;
      cell_t c;
      face_t f;
      real V, sum = 0., sum_V = 0.;
      real ave;
      int zone_ID = 7; // outlet ID
      d = Get_Domain(1);
      t_f = Lookup_Thread(d,zone_ID);
      begin_f_loop(f,t_f)
      t = THREAD_T0(t_f); // get cell thread
      c = F_C0(f,t_f); // get corresponding cell
      V = C_VOLUME(c,t);
      sum_V += V;
      sum += V*C_U_M2(c,t);
      end_f_loop(f,t_f)
      ave = PRF_GRSUM1(sum/sum_V);
      if I_AM_NODE_ZERO_P
      Message("ave = %g\n",ave);
      It is a simple code that calculates and prints the average velocity at a boundary. I used it on both 2D and 3D models (very simple models such as 2D laminar flow in a pipe).
      First, I run the model for a few time steps, e.g. time steps =10. Then I apply the UDF, and continue the simulation.
      When I change the line "sum += V*C_U_M2(c,t);" to  "sum += V*C_U_M1(c,t);" or "sum += V*C_U(c,t);" it perfectly works without error and prints the average velocity. But with C_U_M2(c,t) (or any other _M2 macros) it encounters the segmentation error.
    • Silversea
      Update:
      I tried it on older versions of Ansys, such as 18 and 19, with the same outcome.
      I also used THREAD_STORAGE(t, SV_...))) to test whether the memory has already been allocated as follows:
      if (THREAD_STORAGE(t,SV_U_M2) == NULL)
          Error("error THREAD_STORAGE SV_U_M2");
      and it produced the error. So, it means that memory is not allocated for this macro.
      A question, Am I the only one that gets this problem? Would somebody please confirm that any _M2 macros work?
    • Selawe97
      Hello
      I am getting the same problem also, But i read in the documentaion that data from C_T_M1 is available only if user-defined scalars are defined. and i did not understand what that mea!
      It means you'll need some scalars (look in User Defined tab in the solver). They're extra scalar fields we can use to solve "stuff" as required.
Viewing 5 reply threads
