October 26, 2023 at 3:29 am
Chee Hui Ren
SubscriberHi there,
I am working on connected beams in ANSYS APDL. I have assigned below to the lines
1. 'BEAM188' element
2. 'square hollow beam' sections ID 1 (0.1875")
2. 'square hollow beam' sections ID 2 (0.250")I have assigned sections to all the lines possible before meshing them.
However, some lines appear to have no section assigned to them.
Some of the elements do not have sections assigned to them which I am sure I have already assigned to all the lines.
Below is my APDL code (no loading/boundary conditions are assigned yet)
!Created by: Chee Hui Ren!TY10090-9FINISH/CLEAR,NOSTART/PREP7!Beam ElementET,1,BEAM188 !Beam elementsKEYOPT,1,1,0KEYOPT,1,2,0KEYOPT,1,3,2KEYOPT,1,4,0KEYOPT,1,6,0KEYOPT,1,7,0KEYOPT,1,9,0KEYOPT,1,11,0KEYOPT,1,12,0KEYOPT,1,15,0!Define beam typesSECTYPE, 1, BEAM, HREC, .1875wall, 1SECOFFSET, CENTSECDATA,2,2,0.1875,0.1875,0.1875,0.1875,0,0,0,0,0,0SECTYPE, 2, BEAM, HREC, .250wall, 1SECOFFSET, CENTSECDATA,2,2,0.25,0.25,0.25,0.25,0,0,0,0,0,0!Material PropertiesMPTEMP,,,,,,,,MPTEMP,1,0MPDATA,EX,1,,10007604 !elastic modulusMPDATA,PRXY,1,,0.33 !Poisson's ratioTB,BISO,1,1,2,TBTEMP,0TBDATA,,39885.37799,,,,, !tensile yield strength!Keypoints - TY10090-7K,1,0,12.227,205.118,K,2,0,12.227,116.232,K,3,0,12.227,27.649,K,4,0,12.227,-27.649,K,5,0,12.227,-116.232,K,6,0,12.227,-205.118,K,7,0,4,116.232,K,8,0,4,27.469,K,9,0,4,-27.649,K,10,0,4,-116.232,K,11,94.03,4,205.118,K,12,94.03,4,116.232,K,13,94.03,4,27.649,K,14,94.03,4,-27.649,K,15,94.03,4,-116.232,K,16,94.03,4,-205.118,K,17,92.99,4,116.232,K,18,92.99,4,27.65,K,19,92.99,4,-27.65,K,20,92.99,4,-116.232,!LINES - TY10090-7LSTR,1,2LSTR,2,5LSTR,5,6LSTR,1,7LSTR,2,7LSTR,7,10LSTR,5,10LSTR,10,6LSTR,3,8LSTR,4,9LSTR,7,11LSTR,10,16LSTR,11,1LSTR,6,16LSTR,7,12LSTR,8,13LSTR,9,14LSTR,10,15LSTR,11,13LSTR,13,14LSTR,14,16LPLOT !SHOW LINE!HARDPOINTS & LINES - TY10090-7HPTCREATE,LINE,15,0,COORD,92.99,4,116.232,HPTCREATE,LINE,16,0,COORD,92.99,4,27.65,HPTCREATE,LINE,17,0,COORD,92.99,4,-27.65,HPTCREATE,LINE,18,0,COORD,92.99,4,-116.232,LSTR,2,17LSTR,3,18LSTR,4,19LSTR,5,20!Keypoints - TY10090-8K,21,-2,12.227,205.118,K,22,-2,12.227,116.232,K,23,-2,12.227,27.649,K,24,-2,12.227,-27.649,K,25,-2,12.227,-116.232,K,26,-2,12.227,-205.118,K,27,-2,4,116.232,K,28,-2,4,27.649,K,29,-2,4,-27.649,K,30,-2,4,-116.232,K,31,-86.422,19.613,205.118,K,32,-86.422,19.613,116.232,K,33,-86.422,19.613,27.649,K,34,-86.422,19.613,-27.649,K,35,-86.422,19.613,-116.232,K,36,-86.422,19.613,-205.118,!LINES - TY10090-8LSTR,31,36LSTR,26,36LSTR,21,31LSTR,22,25LSTR,21,22LSTR,25,26LSTR,27,30LSTR,21,27LSTR,30,26LSTR,27,22LSTR,23,28LSTR,24,29LSTR,25,30LSTR,27,32LSTR,28,33LSTR,29,34LSTR,30,35LSTR,27,31LSTR,36,30!HARDPOINTS & LINES - TY10090-8HPTCREATE,LINE,39,0,COORD,-79.606,18.352,116.232,HPTCREATE,LINE,40,0,COORD,-79.606,18.352,27.649,HPTCREATE,LINE,41,0,COORD,-79.606,18.352,-27.649,HPTCREATE,LINE,42,0,COORD,-79.606,18.352,-116.232,LSTR,22,37LSTR,23,38LSTR,24,39LSTR,25,40!Link linesLSTR,1,21LSTR,7,27LSTR,2,22LSTR,8,28LSTR,3,23LSTR,9,29LSTR,4,24LSTR,10,30LSTR,5,25LSTR,6,26LPLOT !SHOW LINE!Loading Keypoints - TY10090-8 (hardpoints on the beams)HPTCREATE,LINE,13,0,COORD,16.2242836,10.8057332,205.118,HPTCREATE,LINE,13,0,COORD,82.9891562,4.96600045,205.118,HPTCREATE,LINE,22,0,COORD,16.2230435,10.7917169,116.232,HPTCREATE,LINE,22,0,COORD,82.9820275,4.88542413,116.232,HPTCREATE,LINE,23,0,COORD,16.2230435,10.7917169,27.649,HPTCREATE,LINE,23,0,COORD,82.9820275,4.88542413,27.649,HPTCREATE,LINE,24,0,COORD,16.2230435,10.7917169,-27.649,HPTCREATE,LINE,24,0,COORD,82.9820275,4.88542413,-27.649,HPTCREATE,LINE,25,0,COORD,16.2230435,10.7917169,-116.232,HPTCREATE,LINE,25,0,COORD,82.9820275,4.88542413,-116.232,HPTCREATE,LINE,14,0,COORD,16.2242836,10.8057332,-205.118,HPTCREATE,LINE,14,0,COORD,82.9891562,4.96600045,-205.118,!Loading Keypoints - TY10090-7 (hardpoints on the beams)HPTCREATE,LINE,28,0,COORD,-9.05645818,12.8443628,205.118,HPTCREATE,LINE,28,0,COORD,-75.8014915,18.6838219,205.118,HPTCREATE,LINE,45,0,COORD,-9.06119572,12.7843408,116.232,HPTCREATE,LINE,45,0,COORD,-75.8510401,18.0560693,116.232,HPTCREATE,LINE,46,0,COORD,-9.06119572,12.7843408,27.649,HPTCREATE,LINE,46,0,COORD,-75.8510401,18.0560693,27.649,HPTCREATE,LINE,47,0,COORD,-9.06119572,12.7843408,-27.649,HPTCREATE,LINE,47,0,COORD,-75.8510401,18.0560693,-27.649,HPTCREATE,LINE,48,0,COORD,-9.06119572,12.7843408,-116.232,HPTCREATE,LINE,48,0,COORD,-75.8510401,18.0560693,-116.232,HPTCREATE,LINE,27,0,COORD,-9.05645818,12.8443628,-205.118,HPTCREATE,LINE,27,0,COORD,-75.8014915,18.6838219,-205.118,!Assigning .250 beamFLST,5,46,4,ORDE,10FITEM,5,1FITEM,5,-15FITEM,5,18FITEM,5,-21FITEM,5,26FITEM,5,-38FITEM,5,43FITEM,5,-45FITEM,5,48FITEM,5,-58CM,_Y,LINELSEL, , , ,P51XCM,_Y1,LINECMSEL,S,_YCMSEL,S,_Y1LATT,1, ,1, , , ,2CMSEL,S,_YCMDELE,_YCMDELE,_Y1!Assigning .1875 beamFLST,5,12,4,ORDE,8FITEM,5,16FITEM,5,-17FITEM,5,22FITEM,5,-25FITEM,5,39FITEM,5,-42FITEM,5,46FITEM,5,-47CM,_Y,LINELSEL, , , ,P51XCM,_Y1,LINECMSEL,S,_YCMSEL,S,_Y1LATT,1, ,1, , , ,1CMSEL,S,_YCMDELE,_YCMDELE,_Y1 -
October 26, 2023 at 6:22 am
Chee Hui Ren
SubscriberI have managed to assign the section to all the meshed profiles. Initially, I was using hard points on the lines to create load locations. This time, I used key points instead. However, it wouldn't locate the points exactly on the lines as it is how APDL program reads it.
Therefore, I am thinking about partitioning my lines with the keypoints being part of the line joining keypoints.
October 30, 2023 at 12:46 pm
Ashish Khemka
Forum ModeratorHi,
It seems that your query is resolved.
Ashish Khemka
- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8806
4658
3151
1680
1470
