March 13, 2023 at 1:46 pm
Sushil Sharma
SubscriberI have two questions in ACP(pre).
1st, I want to extract the section of my model with different color coding for diverse modeling groups. Is it possible to set the color code in ACP(pre)? I want to set a different color for different modeling groups, as in the attached figure.
2nd, to generate an extruded view of my composite element, I create solid models. Does it affect my plywise analysis later on? Is there any other way to generate an extruded view of the model?
Thank you
March 16, 2023 at 3:33 pm
Hello Ashish,
The link is not accessible to me, is there any way to get access on it?
Thank you
Sushil, please see if you can use this link:
Ashish Khemka
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3670
2548
1749
1226
582
