Process Integration and Design Optimization
See input and output parameters when using Mechanical APDL system and want to do DX study
    • Dragana Jandric
      We can define parameters in the MAPDL script and read the script in the MAPDL system. To see the parameters one would need to go to View>Outline on the project page. You should see "Process name.txt", table with the parameters should show up and you can define inputs and outputs.
    • Karthik R
      Administrator
      nThank you for sharing this information. This is very useful.nKarthikn
    • tejas bhagwan
    • tejas bhagwan
      yes
Viewing 3 reply threads
