October 9, 2018 at 11:44 pm
October 10, 2018 at 4:00 am
Aniket
Ansys EmployeeHi mekafime,
can you please elaborate on your issue? It is not very clear to me from the description and the image.
October 10, 2018 at 4:39 am
October 10, 2018 at 4:42 am
mekafime
SubscriberWhen I want select the intermediate node, I can't only can select in the exterior faces ..
October 10, 2018 at 10:23 am
Aniket
Ansys EmployeeYou might not be able to select the node interactively, but you should be able to use the Named selection based on a worksheet to select the node.
Please check:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/wb_sim/ds_NS_worksheet.html
If you are unable to access the link above please see this post and this on how to access help if you are using 19 or above.
October 10, 2018 at 2:26 pm
mekafime
SubscriberThanks !
2064
1279
1096
456
