Photonics
Photonics
Select a new axis of rotation?
    • Albi.Pani
      Hi, given a certain structure for example a triangular prism I would like to rotate it around "x axis" but not around the red point but around another point, for example the barycenter (green point). How can I do it?
    • Amrita Pati
      I believe you will have to rotate the structure and shift it.
      Amrita
    • Albi.Pani
      Ok, so there is no way to rotate the object as I need? It should be a nice thing to implement
    • Amrita Pati
      I believe it is quite straightforward to rotate and shift. But if you think there are some complicated cases when it would make it much simpler to have this feature, you can submit a feature request on ix: Ideas Exchange.
      Amrita
Viewing 3 reply threads
