Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Select beam element by section area value
    • Carlo
      Hello, i need to select some beam elements with the same area value.
      By now, I'm able only to select all the beam in the models with this command:
      esel,s,ename,,188
      Thankyou
    • HuiLiu
      If you know which cross section type you want to select, you can do for example: ESEL,s,SEC,,1. Does this work?
    • Carlo
      I don't know the section type because the beams are beam connections created in workbench
