August 31, 2022 at 4:40 am
laureano.gonzalez
SubscriberHi,
I am running a transient thermal model and would like to see the temperature profile of a group of inner model elements. To do that I created a plane and tried to select the group of inner elements of interest, but instead what I am selecting are the hidden elements on the surface of my model. Could you please share a workaround to select inner elements? thanks in advance.
August 31, 2022 at 2:22 pm
SaiD
Ansys EmployeeHello! You would probably have to create a Named Selection and use the Scoping Method: Worksheet. In the Worksheet, you can use Entity Type: Element and use certain criteria (X location, Y location) and Operator: Range to select the desired elemnts in the interior. You can then create a Temperture output for this Named Selection.
If you need help, you can try downloading the files for the "Baking Gingerbread cookies" problem from here: Heat Transfer Simulation Examples | Ansys Innovation Courses
At about 04:20 in the 'How To Video', you can see the steps used to create a Named Selection using Worksheet.
Hope this helps!
September 7, 2022 at 3:48 pm
dimitri.hamelin
SubscriberHllo,
Maybe you can try to hide some faces or bodies to acces the elements of interest
But the solution of @SaID looks better.
September 8, 2022 at 6:29 am
laureano.gonzalez
SubscriberThanks a lot to both of you. I'll go through both approaches and get back to you with my comments.
2120
1345
1118
461
