September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeIs there an easy way to select multiple faces on a model in SCDM?
October 17, 2017 at 7:07 am
cbhavsar
Ansys EmployeeYes. You can select one or more objects quickly and easily by using the Select tool. Click the first face of your design, hold down the Ctrl key, and then click each individual selection you want to add to or remove from your original selection. For more information, refer to the SpaceClaim Online Help.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5364
3363
2471
1310
1018
