July 26, 2023 at 3:00 pm
Su Costa
SubscriberI'm currently working on a rubber compression problem and need some guidance on how to accurately simulate rubber behavior in my numerical simulations.
I'm seeking advice on which material characterization would be best suited for this purpose and how to implement them effectively.
Questions:
Experimental Test Selection: Among the available tests (uniaxial tension, uniaxial compression, biaxial tension, biaxial compression, and planar tests), which combination is recommended for comprehensive material characterization under compression conditions? Would conducting uniaxial compression, biaxial compression, and planar tests be accurate to model the rubber's behavior accurately for a compression problem?
Converting Uniaxial Tension to Biaxial Compression: As biaxial compression and uniaxial tension tests provide different types of stress states, how can I convert the uniaxial tension test data into equivalent biaxial compression data? Are there established methods or equations for performing such conversions?
Thank you in advance for your expertise and assistance. I'm looking forward to your valuable input and experiences.
July 27, 2023 at 8:29 pm
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
7592
4440
2953
1427
1322
