Selecting Two Surfaces from Single Enclosure Face to Specify FLUENT Boundary Conditions
    • SU252019
      I currently am trying to specify two different outlet boundary conditions from a single enclosure in FLUENT. Is there any way to create two boundary conditions from one enclosure? Picture shown below.
      In the meshing stage, I would like two create two separate named selections from the outlet surface in order to specify two different outlet boundary conditions in FLUENT.
      Any help would be greatly appreciated!
      Yes. You'll need to split/slice the surface and assign labels (named selections) at the geometry or meshing stage. Then set up the boundaries as normal. Why do you want two conditions on the same surface?
    • DrAmine
      For fun good question.
