March 30, 2022 at 4:47 pm
skdubey
SubscriberDear Frnd,
I have constructed the geometry in the solid work and imported in the Ansys using the STEP format. I am not sure what is the problem, I cannot select the inner face for the pressure distribution, whenever, I tried to click on the inner face, it selects the plan above it or the outermost of the geometry any suggestion or help will be appreciated. this is really frustrating.
March 31, 2022 at 12:00 pmKeyur Kanade
Ansys EmployeeSelect outer faces. Right click. Hide faces. Then select inner faces.
Please go through help manual for more details
Regards Keyur
March 31, 2022 at 1:17 pmskdubey
SubscriberI tried to use that, but it taking long time, for complicated and big geometry will take more time. Is there any other way to pass, ??
April 1, 2022 at 2:58 pmRob
Ansys EmployeeIf you're in Ansys Meshing once you've picked the outer surface look in the bottom left of the graphics window for a semi-layered set of coloured squares. The colours correspond to the volume colours, pick the one that corresponds to the surface you're interested in.
2630
2104
1327
1110
461
