May 16, 2023 at 1:57 pm
Martin Štěpánek
SubscriberHello,
I'd like to smooth facetted geometry (the result of a topology optimization), but keep some surfaces without smoothing (following Fig. in orange).
If I select one of the surfaces and use Inverse Selection it works.
But if I select more than one and click Inverse selection, it selects the whole geometry.
How can I unselect more surfaces for Smoothing or some other option?
Thank you.Martin
May 18, 2023 at 7:36 am
Ashish Khemka
Ansys EmployeeHi Martin,
Inverse selection for multiple faces works for me. Can you try doing a box selection instead?
Ashish Khemk
May 18, 2023 at 10:10 am
Martin Štěpánek
SubscriberHi Ashish,
I tried an inverse selection for multiple faces on solid geometry, and it works. However, it does not work for faceted geometry. The faceted geometry is a result of topology optimization.
I tried the inverse selection for multiple faces on another PC with different faceted geometry, but it either does not work. I'm using ANSYS 2023 R1.
I believe more people must have had this problem when validating the model after topology optimization.
Thank you.
Martin Štěpánek
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5162
3275
2453
