Ansys Products
Ansys Products
Selective Results Output Option to Reduce Results File Size
    • Najeeb Rahman
      Is there an option to solve a model for a selective portion, for example, if the model has shells elements coated on the solid elements and the stress request could be made just for shells.
      This results request for a portion of the model reduces the results file size, in NX prgram of the structre analysis.
      There is an option in Workbench, to evaluate the results for shells/surface coating after the solution, but need to request for it before submitting the analysis, if it reduces the results file size and solution run time.
      Thanks for the help.
    • Ashish Khemka
      Hi Najeeb,
      Please see if this is what you are looking for: Obtaining Accurate Stress Using Surface Coating — Lesson 4 - ANSYS Innovation Courses
      Ashish Khemka
    • Najeeb Rahman
      Hello Ashish,
      Thanks for your refering to the link.
      Some FE Analysis programs have options of specific results output request for a certain portion of the FE model and this reduces the results file size, and if a different post processor is used for post processing and creating a 3d html file with results contour, the smalle size file helps to expediate the process.
      I am not aware of this option of selective results option in ANSYS, to make results file size, smaller.
      If there is an option, knowing of this will be helpful.
    • Ashish Khemka
      Please see if the following link helps you:
      Reducing Result File Size in Transient-Thermal-Electric Simulation (ansys.com)
      You can also find these options under Details of Analysis Settings --> Output Controls:
      Ashish Khemka
Viewing 3 reply threads
