Self contact
    • Zoltan Wagner
    • Ankush Choudhary
      Hi Zoltan,
      Could you please elaborate your question?
    • Zoltan Wagner
      Hi
      So basically this inner core is built up from individual smaller cores and as these structure is compressed it folds in, meaning the sides and edges touch. I can't define contact as there is only one geometry but for my project I have to define self contact?
    • Ankush Choudhary
      As I can't see the geometry here, it is difficult to say how you want to generate the contacts. However, for creating a self-contact, you can define the contact and target to the same surface or an edge. For further information, please watch this video.
  • Zoltan Wagner
    This is one of the individual cores and a massive one is buitl from this. So when the entire structure is compressed the inner walls touch. In my simulations I haven't defines anything so the walls just go through each other.
    Thanks
  • Ankush Choudhary
    If you define contact on one surface and target another, contact compability will occur under compression.
  • Zoltan Wagner
    That's great thank you. is there an easy way of doing it as i have 96 of these structures put together
  • Ankush Choudhary
    If there is complete compression, you can try self-contact as well.
  • Zoltan Wagner
    Yes that is what i need to do, do you have a video or a tutorial on how to do that?
  • Ankush Choudhary
    I don't have the tutorial related to it, but you can create a self-contact by making contact and target the same surface.
  • peteroznewman
    Zoltan, if you solve this model in Explicit Dynamics, self contact is automatically created for you by the solver so you don't need to manually create any contacts.
  • Viewing 10 reply threads
