September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow to separate the inflation into a separate cell zone in Fluent?
October 17, 2017 at 7:53 am
Arun Kumar
SubscriberProblem/Description: For MDM problems, it can be advantageous to separate the inflation layer into a separate cell zone. Doing so will allow you to have different MDM settings for the inflation layer than the surrounding elements. An example of its usefulness is a falling rigid object in a fluid domain. If the rigid object is represented as a void in the mesh surrounded by an inflation layer, and the elements surrounding the inflation layer are tet elements, then separating the inflation layer will allow you to specify rigid body motion to the inflation layer (so that the inflation element quality is maintained throughout the simulation) and remeshing/smoothing is only performed on the surrounding tet elements. Solution: There are two ways to separate the inflation layer. 1) If the inflation has a constant # of elements: Adapt > Boundary > Option = Cell Distance > Number of Cells = inflation layers > Boundary Zone = [wall boundary with inflation] > Mark > Mesh > Separate > Cells > Mark > Registers = Marked Zone > Separate. 2) If the inflation elements are a different element type than the rest of the mesh: Initialize > Adapt > Iso-Value > Iso-Values of = Cell Info… > Cell Element Type > Compute > Mark separate zone for, e.g. element type 6, which is triangular prisms. Separate marked zone as above.
April 26, 2020 at 5:10 am
vishwatejakasoju
SubscriberCan someone help me separate inflation into a separate cell zone in fluent 3D.
I am using Fluent 2019 R3 and i dont see any option for Adapt -> boundary.
Any tutorial that helps to understand separating inflation layer into separate cell zones in fluent 3D would be beneficial.
April 26, 2020 at 3:43 pm
Kalyan Goparaju
Ansys EmployeeHello,
This post should help you with what you are looking for.
https://forum.ansys.com/forums/topic/adapt-region/
Thanks,
Kalyan
2600
2088
1319
1108
459
