September 15, 2021 at 6:15 pm
kafom8
SubscriberPlease I am modelling two different materials with an adhesive between. I am using the CZM method. Do I specify a CZM for each layerinterface between the epoxy and each of the materials? I am using contact elements method.
Thanks
Viewing 0 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceTrending discussions- 2022 R1 What’s New PDF/PPTX?
- Prms/ pmean
- separation based debonding,CZM parameters
- Hydrodynamic diffraction and response
- The simulated results of microstrip patch antenna does not match the online example
- Desktop/laptop specification for Ansys forte
- how to simulate piezoelectric patch on ANSYS workbench ?
- Heat simulation – change source wavelength
- Mudjere
- Meshing/Simulation problem
2610
2088
1319
1108
459
