Separation of drag force (pressure and viscous forces) for transient simulation
    • Shiv1510
      Hi everyone,
      I am trying to perform simulation on an undulating aero-foil in Ansys fluent.I understand there is an amazing in-build option to calculate drag on the surface of the aero-foil and plot/save it in time. However, I want to find decomposition of the same drag force into its pressure and viscous components and save it in time.
      I know the report forces option does this very well, but I could only figure out that it works for one particular/last time step/steady state. How can I make it work for transient cases and save the pressure and viscous components of drag separately ?
      Can anyone help me please ?
    • DrAmine
      For pressure force this is straightforward as you have the pressure variable and the facet area. From it you can abstract the viscous component.
    • Shiv1510
      Hi Amine
      Thank you for replying,
      Do I have to define a custom field function for pressure* area ? and apply it as an integral or sum on the surface of the aero-foil ? How would I choose the direction vector for the force ?
      Best regards
      Shiv1510
    • DrAmine
      You need to use the Are Vector to get a force vector (not only area magnitude).
    • Shiv1510
      Do you mean the the X-Face are under mesh options in custom field definition ? (e.g: p*x-face area)
    • DrAmine
      Yes and sum.
    • DrAmine
      also check the exact definition of the force in Fluent as there is use of reference pressure too (check if that value is set in your case)
    • Shiv1510
      Great ! Thanks it worked.
Viewing 7 reply threads
