sequence fluent calling different macros
    • Weiqiang Liu
      hi all,
      I have many source term macros, profile macros and property macros in one source code. I tried to debug my code in VS 2013. In order to know the sequence of fluent calling macros better, I arranged my macros according to the picture below:
      during the process of debugging, I found fluent first calls DEFINE_PROFILE macros and then calls mass source macros. The next called macro should be species source term based on above picture I think. However, fluent just stopped and got stuck after mass source term was called. I surely have hooked my species source macros. I can not figure out why this happen. Can anybody give me some hints or is my thought about sequence of calling right?
      Best regards.
      Weiqiang
    • DrAmine
      Maybe wrong UDF? CAn you use debug messages in your macros: that helps a lot.
    • Weiqiang Liu
      Hi, Amine,
      Yes, like you said, I put a Message0 line in both mass source macro and species source macro. I found only message in mass source macro was displayed in fluent console. obviously specie source macro was not called by fluent. I don't know why.
      Best
      Weiqiang
    • Weiqiang Liu
      hello, Amine,
      I found the reason. It's just because fluent won't call source macro during initialization. Fluent will only call source macros during calculating.
      Best.
      Weiqiang
    • DrAmine
      Yes which is clear from the calling sequence. Glad to see u progressing.
Viewing 4 reply threads
