sequence of animation
    • Jaeha
      I save my file on .hsf however half of my file in .ppm and half in .hsf file. I want to convert it into animation but I can't. How caN I solve this?
    • Nikhil Narale
      If you select a storage type, it should ideally save the all the animation files in that format. From what you are saying, it sounds unnatural. However, FYI, when you save files in .hsf format (which is a 3d format), it will convert those files to .ppm format (which is a 2d format) at the time of creating/writing videos from Results -> Animations -> Playback.
      To understand the issue correctly, can you please upload the screenshots directly in your comment. Ansys staff are not permitted to download attachments.
      Nikhil
