Sequence of boundary conditions for multiple angle-of-attack airfoil analysis
    • alems
      Hello!
      I am currently analyzing lift, drag and moments of an airfoil where I am varying the X and Y components of the inlet velocity. Is there any way to define a sequence of input parameters? I would like to run the calculation repeatedly as I have many points to analyze.
      All help is appreciated, perhaps there is a more convenient alternative to the method I am applying. Thank you.
    • Nikhil Narale
      You can perform parametric study in Ansys Fluent. For detailed information on how to perform parametric study, please refer to this link: Chapter 31: Performing Parametric Studies (ansys.com)
      If you face any issue while accessing the above documentation, refer to this forum discussion: Using Help with links ÔÇö Ansys Learning Forum
      Nikhil
