Set Bodyselection for Result Path by Scripting
    • Niklas Sellmann
      i want to generate a Result for a Path from the Construction Geometry ("Threadrootpath") with a Python Script. The path touches several bodies, but the evaluation should be done only on certain bodies ("body_selection"). The picuture shows the function from the GUI of Ansys Mechanical, that i want to use by the Script but i cant find any documentation for the correct command. Can anyone help me?
      sol=Model.Analyses[0].Solution
      new_sol=sol.AddEquivalentStress()
      new_sol.ScopingMethod=GeometryDefineByType.Path
      new_sol.Location=Threadrootpath
      new_sol.???=body_selection
    • Erik Kostson
      Hi This post shows how to do this: https://discuss.ansys.com/discussion/2491/how-to-set-path-and-geometry-scoping-when-defining-result-object-with-path-as-the-scoping-method All the best Erik
