Set camera angle in cfd post
    • ansysuser
      I wish to be able to specify the view in CFD post. I get the following error on some code that seems to have worked for some people:
    • ansysuser
      Any input?n
    • Surya Deb
      Hello, nThe best way to do this would be to record a session file while you move your model in the 3D Viewer. nThen you can open the recorded .cse (session ) file and modify the camera angles. nOnce you do that, you could then read back that session file and will see the necessary changes.nFor example, something like below should work.nCOMMAND FILE:n CFX Post Version = 19.2nENDnnVIEW:View 1n Camera Mode = User Specifiedn CAMERA:n Option = Pivot Point and Rotationn Pivot Point = 0, 0, 0n Rotation = -90, 0, 0n ENDnnENDnn> updatennYou should try recording and then changing at your end.nI hope this helps.nRegards,nSuryann
