Photonics
Photonics
Set the metallic aluminum material properties
    • 2212296
      Hi guys,
      The aluminum is set as a lossy metal with
      a conductivity of σ = 3.56e+7 S/m,
      how to set it?
      best
    • Guilin Sun
      I think you have set it before as you reported huge memory, and this is why I suggest you to use PEC instead. Please refer this post: https://forum.ansys.com/forums/topic/about-micron-or-millimeter-wave-simulation/
      • 2212296
        Yes, I also set the PEC as you said, but the simulation results obtained are different from those in the article
    • Guilin Sun
      Then you may need to switchback to conductive material, with a poweful coputer as it requires huge memory. Please do not use override mesh to reduce the memory requirement.
      • 2212296
        okay, thank you
