November 1, 2018 at 1:53 pm
heechangna
SubscriberI launched ansys workbench on a machine with 28 cores.
After import aedt file, then I click on "Setup" to open Maxwell. I did as the first screen shot and click on "Test Machine" then I got an error shown in the second screen shot.
I attached the two screen shots.
Any suggestions and/or comments would be very helpful.
Thanks.
-Heechang
November 21, 2018 at 7:03 pm
Randy Kosarik
Ansys EmployeeHello Heechang,
Your screens indicate the job is running from an interactive scheduler submission - as such we comply with allocated resources.
What scheduler is being used - and version?
What version AEDT is being used?
The "test machine" is only when ansoftrsmservice is configured.
Typically, in a scheduler environment, you would not want ansoftrsmservice installed on a compute node.
o0599 is the assigned compute node for your interactive job?
Please send the screenshot showing the original HPC and Analysis Configuration screen
Also, a screenshot showing the error during analysis.
thanks
Randy
November 21, 2018 at 7:33 pm
heechangna
SubscriberHi Randy,
Thank you for the response!
We use moab 9.1.2.
So, this question is from one of our users.
I will ask the user to provide more information.
Thanks.
-Heechang
November 21, 2018 at 7:43 pm
Randy Kosarik
Ansys EmployeeHeechang,
Please also have the user provide the output from:
qstat --version
thanks
Randy
November 21, 2018 at 7:52 pm
heechangna
SubscriberHi Randy,
We use torque for resource manager, and I got
-bash-4.2$ qstat --version
Version: 6.1.2
Commit: 661e092552de43a785c15d39a3634a541d86898e
Thanks!
-Heechang
- Maxwell, HFSS or Q3D?
- Error
2610
2088
1321
1108
459
