July 20, 2023 at 3:40 am
一博 田
SubscriberHello, I would like to ask if it is possible to set up a structure completely above the water surface in aqwa
July 20, 2023 at 11:01 am
Mike Pettit
Ansys EmployeeHello,
Yes, this is possible in Aqwa. The structure will not be considered during the diffraction analysis, so there will be no hydrodynamic coefficients calculated for it.
However, in a time domain calculation the structure will still experience hydrostatic and incident wave forces if it becomes (partially or fully) submerged, as long as the time domain Analysis Type is set to 'Irregular Wave Response' or 'Regular Wave Response' (i.e. no slow drift effects).
I hope this helps!
Mike
July 20, 2023 at 2:11 pm
一博 田
SubscriberHello, do I need any special settings to establish a completely floating structure compared to a normal structure
July 20, 2023 at 2:19 pm
July 27, 2023 at 2:41 pm
Mike Pettit
Ansys EmployeeYou should not need any special settings for the bridge structure: as long as it is non-diffracting, the Aqwa solver will not give any error due to the overlapping elements at each end of the bridge.
Mike
4466
2955
1427
1322
