February 22, 2022 at 10:27 pm
francescocurzio
SubscriberFebruary 23, 2022 at 3:55 pmfrancescocurzio
SubscriberHi Sir, thank you for the interest, but unfortunately this link cant help me! I'm searching informations about the comman OffSet in the menu ElementTool.
March 7, 2022 at 2:17 pmMarch 7, 2022 at 4:37 pmfrancescocurzio
SubscriberHi Sir! Thank you for the suggest, but i have found a solution using the offset command and some adjustments! Ill try the way you suggested!
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
