Setting region
    • OROI
      Hi
      If i want to expand region size to -X and -Y direction how can it be done? Problem is that conductor current terminal need to touch the edge of region, other wise it gives an error message. Should i set region some other way if conductor has "L" shape? I use Maxwell 3D.
    • Navya C
      Hi @OROI
      Why do you want to expand the region in -X and -Y direction? What are you trying to achieve exactly?
      You can also expand the region in +x and +Y direction instead.
      Regards Navya
    • OROI
      Hi
      I thought that to get calculation correct , the vacuum surrounding the conductor must be equal or close equal on all sides. That's why i thought it will need to expand region to -x and -y directions to get calculation correct. If i have straight conductor, then i can set surrounding vacuum equal, but it seems that, i can get correct answers if i expand region only +x and +y directions.
