Setting up directories in ansys
    • kaitova
      I know, you will ask me to be more precise, but could you please give advises in setting up working directory in Ansys?
      I have some model on C drive, some on the another drive. Ansys is installed on C drive. I am experiencing issues in solving the project (usually it happens if i open old project and make some modifications or add additional load cases there).
      Could you please also share your experience on using ACP Pre, it is often failing when I am working with old projects (see above). Is it something in the set up/storage of the ACP subfiles that loses links or it is sth else?
      What is the best approach in your opinion of working with ansys projects, especially shared by somebody.
      Thank you in advance and have a good weekend
Viewing 0 reply threads
