February 17, 2021 at 7:02 pm
roniw
SubscriberWe’re trying to set up remote simulation management on a Redhat Google Cloud server and are following the instructions in the RSM tutorial. However, the setting “Disable access by remote machines” is selected and grayed out such that we cannot unselect it to allow remote simulation (see image). Has anyone run into this and would know how to fix it?
February 19, 2021 at 2:02 pmANSYS_MMadore
Ansys EmployeeHave you installed and started the ansoftrsmservice on the machines?nFebruary 24, 2021 at 2:54 amroniw
Subscriber@roniw Have you installed and started the ansoftrsmservice on the machines?https://forum.ansys.com/discussion/comment/107430#Comment_107430
Ah that was the issue. Thank you! But now I am getting the error:nUnable to start COM engine on : Unable to reach AnsoftRSMService. Check if the service is running and if the firewall allows communication. nI've verified the RSM is running and I've added specific port exceptions to my Windows firewall in addition to the Ansys exceptions. There is no firewall on my Redhat machine.nFebruary 26, 2021 at 5:45 pmANSYS_MMadore
Ansys EmployeeAre you trying to just solve remotely on the one Redhat machine, from your local Windows machine?nThe RSM service listens on port 32958 and spawns the appropriate comm services which create new ports back - these could blocked. These ports are dynamic and cannot be set to static.nAt windows end we can give application level exceptions for RSM, the UI and the comengines. With this there is no issue as far as windows to windows analysis.nFor windows to linux solves, at windows end we can still give application level exceptions and at the linux end or at the hardware firewall end, we need to open up firewall for ephemeral or dynamic ports for both windows side range and the linux side range ( if the ranges are not the same).March 11, 2021 at 3:52 pmroniw
SubscriberYup! I've put in inbound and outbound rules for that port on Windows. I don't know how to open dynamic ports on either end though. Do I need to allow the full 49152 to 65535 range?nViewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5290
3311
2471
