November 16, 2018 at 6:38 am
rumth
SubscriberI have got the data after simulation. I have selected velocity form autosave list. I am also able to show the contours of velocity in CFD--post. But while trying to plot the velocity vector, an error occurring that 'velocity is not a variable'. But I have checked the variable list and velocity is in the list. How can I set velocity as a variable to show the velocity vector?
Thanks,
Raju.
November 16, 2018 at 6:45 am
DrAmine
Ansys EmployeeActually the vector plot is using the velocity to create the vectors. Under "Geometry" what do you see as Variable? Actually you would choose "Velocity" and just click apply.
Which version are you using? And what do you mean with "Autosave": Are you using CDF-Post compatible files? Try using legacy *.dat files.
EDIT: Moving to Results and Post-Processing
November 16, 2018 at 7:29 am
rumth
SubscriberUnder Geometry, only 'Normal' is showing.
My version is 18.2.
Yes, I have used CDF-Post compatible files.
How to use legacy *.dat files? Where is the option?
I am not clear 'EDIT: Moving to Results and Post-Processing'. Can you explain please?
November 16, 2018 at 8:23 am
November 16, 2018 at 8:34 am
rumth
SubscriberYes, I am getting the same options. Usually this options work perfectly.
Used 'calculation activities' option to save data in 'CFD-Post' mode and got data as '*.cdat' files.
In present case I run the simulation in cluster and got data from cluster and facing the problems.
November 16, 2018 at 8:38 am
Keyur Kanade
Ansys EmployeeHow did you export it to CFD Post from Fluent?
Which options you used in Fluent to export data?
Are you using transient simulation?
November 17, 2018 at 8:18 am
DrAmine
Ansys EmployeeJust check if you can read the .cas and .dat files of your run in CFD Post. Perhaps is something missing in your exported files. -
August 7, 2019 at 5:41 pm
Muchanical
SubscriberHello RajuMath,
I had the same problem and I solved it. If you still have this problem you should check the option you used in Fluent to export data as the others already wrote.
As you said you can plot the velocity-contour in CFD-Post because if you export "Velocity" you can't plot any vector because "Velocity" is scalar. I think it is the velocity magnitude without any direction. You need to export "Axial Velocity" and "Radial Velocity". If one of them is missing, you will have issues in CFD-Post plotting a vector or a path line.
I am not sure but I think you don't even need the velocity magnitude to plot vectors. The axial and radial component should be enough.
On my case, I have a 2D axisymmetric simulation.
Best regards,
Mustafa
2706
2142
1355
1144
462
