Setting velocity of particle in a stagnant vertical liquid column.DPM
    • Abdelrahman92
      Hi
      I want to study the terminal settling velocity of particle in a vertical liquid column. The liquid is stagnant (has no velocity). How can I specify this in Ansys fluent?. I tried specifying zero inlet velocity of liquid as
      Read the section in the manual on standard initialisation.  Note, given DPM assumes spheres it'll be quicker to find the relevant Stokes equation and use that.
    • Abdelrahman92
      Thanks for your reply!
      But I didn't get you. Which section you are referring for?. If you mean the user guide, could you tell me which chapter exactly ?
      Look for initialisation in the Fluent User's Guide.
Viewing 3 reply threads
