June 17, 2020 at 4:57 pm
June 17, 2020 at 7:24 pm
June 17, 2020 at 7:31 pm
fishinevich
SubscriberHello,
Thank you for your response. The screenshot I took is when my mesh file was loaded. I'm not sure why this is occurring.
June 18, 2020 at 12:39 am
Karthik R
AdministratorThat's odd. Is this something that you are able to reproduce at your end? Are you working with Fluent standalone or using Fluent on WorkBench?
Thanks.
Karthik
June 18, 2020 at 12:48 am
fishinevich
SubscriberI am working with Fluent from Workbench
June 18, 2020 at 10:32 am
Ansys EmployeePlease can you post the messages from the Fluent text window?
June 19, 2020 at 6:28 pm
June 22, 2020 at 10:53 am
Ansys EmployeeWhat did you label the fluid and solid regions as in Meshing?
June 24, 2020 at 7:52 pm
fishinevich
SubscriberThe program automatically labeled everything as a fluid. How can I change this?
June 24, 2020 at 8:35 pm
Karthik R
AdministratorGroup all solid bodies (that have the same material properties) into a single named selection called 'solid'. Similarly group all Fluid volumes into another one called 'Fluid'. Fluent should retain these.
Thanks.
Karthik
June 26, 2020 at 5:52 pm
fishinevich
SubscriberThank you all for your assistance!
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3694
2564
1765
1234
590
