September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow do I setup ohmic heating using SOFC?
October 17, 2017 at 6:19 am
admin
Ansys EmployeeUsing the SOFC module, when considering ohmic heating in such collector, the following settings must be made. From the Model Parameters tab of the SOFC Model panel, turn on Enable Volumetric Energy Source. In at least one zone, make the following settings: 1. Turn on the Solid or Fluid option from Source Terms 2. Select the Source Terms tab, open the Energy Source panel and click on the Edit of Energy 3. In this panel, set the Number of Energy Sources to 1 and specify the udf source::sofc. When performing this configuration, ohmic heating is taken into account in all zones. Note: It cannot be considered only in a particular zone.
2524
2066
1279
1096
457
