Ansys Free Student Software
Setup shut down while run calculation
    • imranalif
      Hi Everyone,
      I was running my calculation for 12 hours. Suddenly, the setup window closed.
      May I know what is the possible cause for this issue?
      I reopen the setup , however it doesn't say anything on the console.
      it halts again and showing this message
      Update 1
      Have a look in the Workbench folder to see if there's a .trn fluid in the /FLU folder. That may have something useful in it.
    • imranalif
      Hi rwoolhou,
      Unfortunately, I couldn't find anything there. It seems it never compute from the start.
      Performance Timer for 0 iterations on 4 compute nodes
        Average wall-clock time per iteration:              0.000 sec
        Global reductions per iteration:                        0 ops
        Global reductions time per iteration:               0.000 sec (0.0%)
        Message count per iteration:                            0 messages
        Data transfer per iteration:                        0.000 MB
        LE solves per iteration:                                0 solves
        LE wall-clock time per iteration:                   0.000 sec (0.0%)
        LE global solves per iteration:                         0 solves
        LE global wall-clock time per iteration:            0.000 sec (0.0%)
        LE global matrix maximum size:                         0
        AMG cycles per iteration:                           0.000 cycles
        Relaxation sweeps per iteration:                        0 sweeps
        Relaxation exchanges per iteration:                     0 exchanges
        LE early protections (stall) per iteration:           0.000 times
        LE early protections (divergence) per iteration:      0.000 times
        Total wall-clock time:                              0.000 sec
      Does anyone knows how big the file per iteration? It took so much hard drive space.
      If you're saving data every iteration it'll write a case & data file each time: the size will depend on the cell count (mesh) and number of models active.
    • imranalif
      Thank you very much rwoolhou,
      I will try method suggested in link below.
      https://studentcommunity.ansys.com/thread/how-to-run-simulations-without-taking-too-much-computer-space/
Viewing 4 reply threads
