shaft meshing with multizone method
    • sentenza
      Good morning, can you help me with shaft meshing in order to have a mesh like this image? I tried with multizone and it worked but sometimes I get an error :" some elements are not compliant with the applied shape checking criteria". The strange thing is that I have this error with similar shafts with differences just in diameter and lenght. Do you have any suggestions or other techniques to generate that kind of mesh? thanks a lot!
    • Sandeep Medikonda
      What mesh controls are you using?
      Have you tried decomposition and meshing? Please see the videos in this playlist:
      https://www.youtube.com/playlist?list=PL0lZXwHtV6Om3aXTjY_CyOSeqfCPuD3Mf
      Sandeep
    • sentenza
      thanks, i will try decomposition
