November 10, 2020 at 7:17 pm
jchokan
SubscriberHello, Previously when I had to perform structural analysis on a multi-body part in Discovery AIM, I would prepare the model in Spaceclaim, and used the "Group" option for the Share Topology feature so that the bodies would be grouped, but would not merge or share faces/edges with each other. I would then export the model into Discovery AIM to run the structural simulation. Now, I am using Discovery AIM 2020 R2 and not using spaceclaim at all, but preparing the model in AIM's embedded geometry modeler. I can not see an option to Group the share topology in this embedded modeler, all I see is the sharing tool, but I believe that this merges/shares faces and that I do not want. The mesh is failing whenever I use the share tool and that is the only difference between the old procedure and the new one.Is there a feature in AIM 2020's embedded geometry modeler to set the model's shared topology to "Group" like Spaceclaim had? Thanks
November 11, 2020 at 8:14 am
Subashni Ravichandran
Ansys EmployeeHello Jchokan
Let me check with my team and get back to you on this.
May 3, 2021 at 7:12 am
rain
SubscriberHello Subashni
I have the same question.
Can I set shared topology in discovery 2021R1 ?
Thanks
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3778
2579
1825
1242
598
