March 1, 2023 at 6:42 am
Sushil Sharma
SubscriberI am trying to perform a static analysis of a wind turbine blade. I used share topology for the common joint line of the sections I used to model the blade. When I try to do the static analysis, it shows the joint status as far open. How can I solve this issue? I wanted to resolve it using a pinball radius, but it didn't work. Here attached the blade 3D and joint information table.
March 1, 2023 at 2:09 pm
Ashish Khemka
Ansys EmployeeHi Sushil,
Can you remove the regions that are already sharing topology from the region of contact? Regions that are already sharing the topology need not be included in contact definition.
Ashish Khemka
March 1, 2023 at 3:43 pm
Sushil Sharma
SubscriberThank you
If that's the case, then why does the program automatically generate the contact region? In my case I use shared topology to share the common edge, Does that mean I didn't have to assign any contact definition?
March 1, 2023 at 4:15 pm
March 2, 2023 at 1:40 pm
Sushil Sharma
SubscriberCan we do the convergence study of the composite ACP(pre-preg) model? I assigned the layup information and did the static analysis, and tried to study the convergence in deflection output, but it did not offer the convergence tool. I tried changing the material to aluminium, and it worked. Please explain why the convergence tool doesn't work for a composite material assignment.
Thank you
March 2, 2023 at 2:18 pm
SubscriberHow will knowing why the convergence tool doesn't work help you?
March 2, 2023 at 3:02 pm
Sushil Sharma
SubscriberI want to check whether the outputs are within the convergence limit. I tried it following the adaptive convergence tutorial, but in my case (material defined as composite ACP), there isn't a convergence tool to track the refinement. When I use the same model (with homogeneous material), I can use a convergence tool. How can I perform a convergence study of my model with material as ACP composite? Is there any separate way for composite material?
Thank you
March 2, 2023 at 4:52 pm
SubscriberYou can do a convergence study manually by using Mesh Sizing controls to set the element size in the neighborhood of the peak stress. Solve the model four or five times to get four or five points on a Peak Stress vs Element Size chart.
The element size changes should have a constant ratio. A good ratio is between 1.5 and 2.0
For example, using a ratio of 2.0, if your initial element size was 1 m then you would remesh to get a series of models at element sizes of 1.0, 0.5, 0.25 and 0.125 m.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3688
2552
1761
1234
590
