February 4, 2022 at 12:13 pm
Sardar
SubscriberHi
I am meshing three bodies for multiple reference frame method, two (rotary, for two rotors) being encompassed in the other one (stationary). Thus, I have two interfaces. Like this:
February 4, 2022 at 12:43 pmSardar
February 9, 2022 at 6:25 amSardar
SubscriberAnswering my own question:
Those so-called "bad" cells are there because you have chosen the"hex core" option in the "method" windows. Changing "hex core"to "hex dominant" fixes your problem. I guess the terms speak for the difference between them.
February 22, 2022 at 1:11 pmpeteroznewman
SubscriberHex Dominant meshing is appropriate for Structural models because we care about the mesh quality on the surface of the part, and can tolerate poor element shapes on the interior.
Hex Dominant meshing should never be used for CFD meshing because you can't tolerate poor element shapes on the interior.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3744
2573
1809
1236
594
