Preprocessing
Preprocessing
Shared Topology Fails
    • peteroznewman
      This quarter model has an acceptable mesh that includes inflation and other mesh controls. I lengthened the bolt to put the midpoint at the top of the cube to have nodes line up for the contact definitions.
      I sliced the Bolt to get the nodes to line up at the top of the block.
      After the bolt is sliced and the two bodies are placed in a multibody part, the mesh fails to honor the shared topology.
      I'm disappointed that there is not a clear warning that the shared topology has failed.
      If all the mesh controls are removed from the Bolt, then the shared topology works.
Viewing 0 reply threads
