January 28, 2020 at 12:26 pm
Gijoys4v
SubscriberWhat you mean by shared topology? If I have some layers that is in bonded contact, can I replace it with shared topology? Will it give same result, if we do any type of structural analysis(like bending, twisting, tension etc.)?
January 28, 2020 at 3:15 pm
SubscriberBonded contact is useful if you want to study failure of the interface between layers. Search for Cohesive Zone Model.
If all you want is to have the load transfer from one layer to the next, then shared topology allows the two layers to share nodes at the interface.
January 28, 2020 at 3:32 pm
Gijoys4v
Subscriberhttps://forum.ansys.com/forums/topic/twisting-of-very-thin-layered-sheet/
In the discussion above, actually I want to find out the normal strain in the 1micrometer layer during the twisting of the whole layer. So if we use shared topology instead of bonded contact the result may change? Also when I tried with bonded contact, the solver doesn't converge. So is there any method to rectify the problem.? In actual case the layers are in bonded contact with each other
January 28, 2020 at 3:41 pm
SubscriberWith either shared topology or bonded contact, you can plot the strain of just one body, separate from the adjacent bodies.
The results can change a little from shared topology to bonded contact because the contact elements have their own properties. It is cleaner to use shared topology.
What direction are you calling normal?
January 28, 2020 at 3:57 pm
- A solver pivot warning or error has been detected
8740
4658
3151
1678
1452
