January 7, 2023 at 10:07 pm
mmia1
SubscriberHi
I have modeled two pipes and zero length elastic spring was used at the connection joint. Could anyone please help me telling how I can get shear force and bending moment at the connection joint as below. For shear force and bending moment of this connection which option in LSDyna to be requested in the code.
January 10, 2023 at 7:14 pm
Jim Day
Ansys EmployeeIt's unclear what type of spring is used and how that spring is attached to the pipes. Your figure makes me think the pipes are modeled with shells. Maybe that's not the case. But anyway, you can get forces and moments at a cross-section using *DATABASE_CROSS_SECTION_PLANE (defines location of cross-section) and *DATABASE_SECFORC (defines time interval for output of cross-section data to secforc).
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2656
2120
1347
1118
461
