July 3, 2023 at 12:48 pm
ChiDB
Subscribergood afternoon, how do I view the shear and moment diagram of a reinforced concrete beam on ansys? I drew the reinforcements as lines and then I gave the section and in model type I put "reinforcement" In this way, however, I can not have the diagram of the cut and the moment. How should I do? Thanks for the help
July 4, 2023 at 9:48 am
Nanda Veralla
Ansys EmployeeHello ChiDB,
Have you tried using beam results as shown in screenshot below? Let me know if this doesn’t help.
Nanda.
July 4, 2023 at 10:04 am
July 4, 2023 at 10:21 am
Nanda Veralla
Ansys EmployeeHello chiDB,
You can use the above said tool, by following this path solution--> Insert--> beam results--> Total shear-Moment diagram
Can you see this option in your ansys product. If not, can we know what product are you using?
Nanda
July 4, 2023 at 12:10 pm
ChiDB
SubscriberCiao, no non riesco a vedere "risultati trave" (ho allegato immagine) . Ho la versone per studenti.
Potrebbe essere un problema di armatura che ho inserito come rinforzo?
July 4, 2023 at 12:46 pm
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
- Acoustics model in Ansys 18.1
7712
4484
2957
1435
1322
