August 20, 2019 at 3:44 pm
student_ansys
SubscriberI have a tube in Fluent, and need to see shear stress in a cross-section of the tube (not all the wall). In other words, I need to partition the cylinder into small segments (sub-tubes) and see the shear stress contours in each segment. My model was made from mesh (not geometry). Any idea, how can I do that?
Thank you
August 21, 2019 at 9:50 am
Ansys EmployeeI'm not sure what you mean, but will an iso-surface do the job? You may need to combine with a custom field function if you need an "odd" location/angle or non-planar surface.
August 21, 2019 at 3:25 pm
August 22, 2019 at 11:19 am
DrAmine
Ansys EmployeeFluent keep track of shear stress at walls. In a volume you need to reconstruct that by the available velocity derivatives
August 22, 2019 at 2:37 pm
student_ansys
SubscriberI need to see shear stress in the wall but not the whole wall. I just need to see shear stress in the specified sections (in the wall).
Thanks
August 22, 2019 at 8:03 pm
DrAmine
Ansys EmployeeThen try clip the wall.
2656
2120
1347
1118
461
