February 28, 2020 at 2:29 pm
rg
SubscriberIf I create a bend of 90 (or with other gradations and indifferent) and then change it with the move command or from the properties, it develops it in a different way than if I create it from new.
This way I have wrong withdrawals (fold deduction)Why?
I am attaching a video to make you understand better
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
rg
SubscriberNaresh Patre
February 28, 2020 at 4:22 pm
March 2, 2020 at 6:40 am
Subashni Ravichandran
Ansys EmployeeHello Robert
Yes, that is the correct reasoning.
March 2, 2020 at 7:02 pm
ERab
Ansys EmployeeHi Robert , as you showed in the video, rotating with move from 1 side of the wall vs the other is different. in 1 case (inner wall face) it maintains the center axis of the bend...in the other case (face on the outside wall) it maintains the intersection between the 2 outer wall faces
Also as you showed, picking the different options when you create the bend will have different impacts, and some match up and some don't, but you can always add 3D dimensions from the detail tab to the 3D model and use them to make adjustments
March 4, 2020 at 1:47 pm
rg
SubscriberEthan Rabinowitz Thank you
3810
2589
1843
1244
600
