Discovery Import
Discovery Import
Sheet metal
    • rg
      Hi
      If it's not possible , can the component thickness be recalled in the bom table?
      Is it possible to add in the subsequent versions of spaceclaim the function that recalls the thickness of the sheet metal components in the table?
      Best Regards
    • Brian Bueno
      Robert
      The work around would be to create a custom component property and add the thickness value there.  The property value would have to be modified manually each time the thickness was changed, but this could be shown in the BOM column.
    • rg
      Brian Bueno I did so, I thought we could get the field to fill out automatically.
      It would have been nice if he could automatically read the thickness of the component and recall it automatically in the table
      Thank You
